跳转到主内容
Dell XPS 17 L702X Palm Rest Replacement
你所需要的
  1. Dell XPS 17 L702X Palm Rest Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Palm Rest Replacement: 步骤 2 中的图像 1,2 Dell XPS 17 L702X Palm Rest Replacement: 步骤 2 中的图像 2,2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Palm Rest Replacement: 步骤 3 中的图像 1,2 Dell XPS 17 L702X Palm Rest Replacement: 步骤 3 中的图像 2,2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Palm Rest Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Palm Rest Replacement: 步骤 5 中的图像 1,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 5 中的图像 2,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 5 中的图像 3,3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Palm Rest Replacement: 步骤 6 中的图像 1,2 Dell XPS 17 L702X Palm Rest Replacement: 步骤 6 中的图像 2,2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Palm Rest Replacement: 步骤 7 中的图像 1,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 7 中的图像 2,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 7 中的图像 3,3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Palm Rest Replacement: 步骤 8 中的图像 1,1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Palm Rest Replacement: 步骤 9 中的图像 1,2 Dell XPS 17 L702X Palm Rest Replacement: 步骤 9 中的图像 2,2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Palm Rest Replacement: 步骤 10 中的图像 1,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 10 中的图像 2,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 10 中的图像 3,3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Palm Rest Replacement: 步骤 11 中的图像 1,2 Dell XPS 17 L702X Palm Rest Replacement: 步骤 11 中的图像 2,2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Palm Rest Replacement: 步骤 12 中的图像 1,1
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Palm Rest Replacement, Palm Rest: 步骤 13 中的图像 1,1
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Palm Rest Replacement: 步骤 14 中的图像 1,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 14 中的图像 2,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 14 中的图像 3,3
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Palm Rest Replacement: 步骤 15 中的图像 1,1
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Palm Rest Replacement: 步骤 16 中的图像 1,1
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Palm Rest Replacement: 步骤 17 中的图像 1,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 17 中的图像 2,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 17 中的图像 3,3
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Palm Rest Replacement: 步骤 18 中的图像 1,2 Dell XPS 17 L702X Palm Rest Replacement: 步骤 18 中的图像 2,2
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Palm Rest Replacement: 步骤 19 中的图像 1,2 Dell XPS 17 L702X Palm Rest Replacement: 步骤 19 中的图像 2,2
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Palm Rest Replacement: 步骤 20 中的图像 1,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 20 中的图像 2,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 20 中的图像 3,3
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Palm Rest Replacement: 步骤 21 中的图像 1,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 21 中的图像 2,3 Dell XPS 17 L702X Palm Rest Replacement: 步骤 21 中的图像 3,3
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Palm Rest Replacement: 步骤 22 中的图像 1,1
    • Remove the palm rest from the laptop.
结论
另外一个人完成了本指南。
Shin Sul
于10/02/15注册
544 声望
创作了3篇指南
团队
CSU Fullerton, Team 2-6, Bruce Fall 2015 CSU Fullerton, Team 2-6, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G6
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 1,170
