简介
If your Dell XPS 15 computer screen (model L501X/L502X) is having display issues that have to do with a malfunctioning screen, use this guide to replace the screen.
Before using this guide, inspect the computer screen and make sure that the display issues are rooted from screen failure rather than from internal hardware issues.
This guide includes work with small components and data storing components. When handling both internal and external computer hardware, be cautious of any static that may result from maneuvering any electrical pieces.
Make sure to turn off the device and unplug it from any electrical outlets before beginning the technical guide.
你所需要的
Remove the black battery bar from the computer before continuing any further operations.
Unscrew the three 5mm Phillps #2 screws on the left side of the back panel.
Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
Grab the screen on both sides and pull upward to remove the entire screen from the computer.
Swap your damaged screen with your replacement Dell XPS 15-L502X screen and reassemble your computer.
Reassembling your Dell XPS 15-L502X can be done by following the instructions to this guide in reverse order.
6等其他人完成本指南。
