跳转到主内容
Dell XPS 15-L502X RAM Replacement
你所需要的
  1. Dell XPS 15-L502X RAM Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the black battery bar from the computer before continuing any further operations.
    • Unscrew the three 5mm Phillps #2 screws on the left side of the back panel.
  2. Dell XPS 15-L502X RAM Replacement: 步骤 2 中的图像 1,1
    • Lift up the left side of the panel.
    • There are three tabs holding in the right side of the panel. Pull the panel up and away from these tabs to remove it.
  3. Dell XPS 15-L502X RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Locate both of the RAM slots right behind the back panel.
  4. Dell XPS 15-L502X RAM Replacement: 步骤 4 中的图像 1,1
    • Use a black spudger to press the clips holding the RAM outward. You should hear a "click" sound.
    • Once both clips have been released, the RAM will be released at a 45 degree angle.
  5. Dell XPS 15-L502X RAM Replacement: 步骤 5 中的图像 1,1
    • Carefully grab the RAM with both hands and pull outward.
    • Repeat steps 4 & 5 to remove the second RAM.
    • Both RAMs should come out without much force. Do not attempt to pull the RAM out with force as this could damage the fixture holding the RAM.
结论
另外一个人完成了本指南。
Vishal
于09/21/15注册
772 声望
创作了6篇指南
团队
IUPUI, Team 2-3, Baechle Fall 2015 IUPUI, Team 2-3, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S2G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 30
总计 2,057
