跳转到主内容
Dell XPS 15-L502X Front Cover Replacement
你所需要的
  1. Dell XPS 15-L502X Front Cover Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Before prying up on the cover, you may have to first remove a screw located inside the battery compartment (M2X3) and release the two latches. If you don't release the latches, you may snap the cover.
    • Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
    • Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
    • Cracking sounds are normal. Be careful and take your time removing this panel.
  2. Dell XPS 15-L502X Front Cover Replacement: 步骤 2 中的图像 1,1
    • Work your fingers underneath the cover. Then, delicately pull the cover off of the computer.
    • The mouse pad is connected to the rest of the computer via two cables underneath the cover. These cables must be unhooked before the cover can be completely removed.
  3. Dell XPS 15-L502X Front Cover Replacement: 步骤 3 中的图像 1,2 Dell XPS 15-L502X Front Cover Replacement: 步骤 3 中的图像 2,2
    • Unhook the cables connected to the mouse pad by flipping up the black tabs that hold either cable in place.
    • Releasing these cables can be done by hand or by using a spudger.
结论
另外一个人完成了本指南。
Kyle Compton
于09/16/15注册
398 声望
撰写一个指南
团队
IUPUI, Team 2-3, Baechle Fall 2015 IUPUI, Team 2-3, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S2G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 26
总计 2,747
