跳转到主内容
Dell XPS 15 Motherboard Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Dell XPS 15 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell XPS 15 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 15 Motherboard Replacement: 步骤 2 中的图像 1,2 Dell XPS 15 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 15 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 15 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 15 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover.
  6. Dell XPS 15 Motherboard Replacement, Battery Disconnection: 步骤 6 中的图像 1,2 Dell XPS 15 Motherboard Replacement, Battery Disconnection: 步骤 6 中的图像 2,2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 15 Motherboard Replacement, Fan: 步骤 7 中的图像 1,3 Dell XPS 15 Motherboard Replacement, Fan: 步骤 7 中的图像 2,3 Dell XPS 15 Motherboard Replacement, Fan: 步骤 7 中的图像 3,3
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Dell XPS 15 Motherboard Replacement: 步骤 8 中的图像 1,2 Dell XPS 15 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Dell XPS 15 Motherboard Replacement: 步骤 9 中的图像 1,2 Dell XPS 15 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Dell XPS 15 Motherboard Replacement: 步骤 10 中的图像 1,2 Dell XPS 15 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
  11. Dell XPS 15 Motherboard Replacement, Battery: 步骤 11 中的图像 1,2 Dell XPS 15 Motherboard Replacement, Battery: 步骤 11 中的图像 2,2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  12. Dell XPS 15 Motherboard Replacement: 步骤 12 中的图像 1,2 Dell XPS 15 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Do not pull up.
  13. Dell XPS 15 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  14. Dell XPS 15 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the battery.
  15. Dell XPS 15 Motherboard Replacement, Motherboard: 步骤 15 中的图像 1,2 Dell XPS 15 Motherboard Replacement, Motherboard: 步骤 15 中的图像 2,2
    • Remove the eight 4 mm Phillips #0 screws from the motherboard.
  16. Dell XPS 15 Motherboard Replacement: 步骤 16 中的图像 1,3 Dell XPS 15 Motherboard Replacement: 步骤 16 中的图像 2,3 Dell XPS 15 Motherboard Replacement: 步骤 16 中的图像 3,3
    • Locate the red and black cable connector at the bottom right of the motherboard.
    • Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up.
  17. Dell XPS 15 Motherboard Replacement: 步骤 17 中的图像 1,3 Dell XPS 15 Motherboard Replacement: 步骤 17 中的图像 2,3 Dell XPS 15 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Use tweezers to flip open the Zero Insertion Force (ZIF) connector.
    • Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself.
  18. Dell XPS 15 Motherboard Replacement: 步骤 18 中的图像 1,3 Dell XPS 15 Motherboard Replacement: 步骤 18 中的图像 2,3 Dell XPS 15 Motherboard Replacement: 步骤 18 中的图像 3,3
    • Use tweezers to flip open the white ZIF connector.
    • Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself.
  19. Dell XPS 15 Motherboard Replacement: 步骤 19 中的图像 1,3 Dell XPS 15 Motherboard Replacement: 步骤 19 中的图像 2,3 Dell XPS 15 Motherboard Replacement: 步骤 19 中的图像 3,3
    • Use tweezers to flip open the ZIF connector.
    • Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself.
  20. Dell XPS 15 Motherboard Replacement: 步骤 20 中的图像 1,2 Dell XPS 15 Motherboard Replacement: 步骤 20 中的图像 2,2
    • Use tweezers to detach the black cable connector out of its socket by pulling it to the right.
  21. Dell XPS 15 Motherboard Replacement: 步骤 21 中的图像 1,3 Dell XPS 15 Motherboard Replacement: 步骤 21 中的图像 2,3 Dell XPS 15 Motherboard Replacement: 步骤 21 中的图像 3,3
    • Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right.
  22. Dell XPS 15 Motherboard Replacement: 步骤 22 中的图像 1,2 Dell XPS 15 Motherboard Replacement: 步骤 22 中的图像 2,2
    • Locate the connector at the top right of the motherboard.
    • Use tweezers to detach the cable connector from its socket by pulling it to the right.
  23. Dell XPS 15 Motherboard Replacement: 步骤 23 中的图像 1,3 Dell XPS 15 Motherboard Replacement: 步骤 23 中的图像 2,3 Dell XPS 15 Motherboard Replacement: 步骤 23 中的图像 3,3
    • Locate the last black cable connector.
    • Use tweezers to detach the black cable connector from its socket by pulling it to the right.
  24. Dell XPS 15 Motherboard Replacement: 步骤 24 中的图像 1,1
    • Use your hands to lift up the motherboard.
结论
12等其他人完成本指南。
Evan Shui
于04/26/17注册
320 声望
撰写一个指南
团队
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G6
5 名成员
创作了30篇指南
2条评论
where is camera cable
phong thanh - 回复
Wow man that is awesome job. Where can you get a newer motheboard for the same laptop?
R E - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 37
过去 30 天: 175
总计 23,755
