跳转到主内容
加入维修社区 - 创建账户
Dell XPS 15 Memory Replacement
你所需要的
  1. Dell XPS 15 Memory Replacement, Memory: 步骤 1 中的图像 1,1
    • First turn notebook upside down.
  2. Dell XPS 15 Memory Replacement: 步骤 2 中的图像 1,2 Dell XPS 15 Memory Replacement: 步骤 2 中的图像 2,2
    • Take the battery out, before working inside of the computer by pulling the tab shown to the left.
    • The battery can easily be removed.
  3. Dell XPS 15 Memory Replacement: 步骤 3 中的图像 1,3 Dell XPS 15 Memory Replacement: 步骤 3 中的图像 2,3 Dell XPS 15 Memory Replacement: 步骤 3 中的图像 3,3
    • You can see the big service lid, which is secured by three philips screws. The screws won't come out completely. The screw in the middle is a bit longer than the other ones.
    • After loosening the screws, the lid should stick out a few milimeters as shown in the second image.
    • You can now remove the lid with your finger. It will make some noise because the lid is also secured by some clips.
  4. Dell XPS 15 Memory Replacement: 步骤 4 中的图像 1,3 Dell XPS 15 Memory Replacement: 步骤 4 中的图像 2,3 Dell XPS 15 Memory Replacement: 步骤 4 中的图像 3,3
    • Inside you can see the two memory modules. There are two tabs on each side of each module. By pulling them away from the module, the module will jump out at a 45° angle as seen in the second image.
    • Now you can simply pull out the module and replace it. You have to remove the first module to get to the second one.
结论
另外一个人完成了本指南。
Clemens Harpf
于11/20/13注册
10 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 32
总计 4,390
