跳转到主内容
Dell XPS 15 L521X Hard Drive Replacement
你所需要的
  1. Dell XPS 15 L521X Hard Drive  Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X Hard Drive  Replacement: 步骤 2 中的图像 1,1
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X Hard Drive  Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Find and remove the four .4cm phillips head screws holding the hard drive in place.
  4. Dell XPS 15 L521X Hard Drive  Replacement: 步骤 4 中的图像 1,1
    • Gently unplug and remove the hard drive
结论
2等其他人完成本指南。
SHELDON SANTOS
于03/19/18注册
614 声望
创作了6篇指南
团队
一条评论
This was a helpful tutorial, except for two small points. #1 - The yellow & red dots on step 1 are reversed; the T5 screws are the six along the two edges of the back panel and the P0 (Phillips #0) screws are under the face plate. #2 - the battery cable should ALWAYS be unplugged for component safety prior to doing any work on a laptop. An additional safety step (though optional) would be to physically remove the battery from the laptop prior to doing any work on it.
ICU Alex - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 1,118
