跳转到主内容
Dell XPS 15 9570 Wireless Card Replacement
你所需要的
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: 步骤 2 中的图像 1,3 Dell XPS 15 9570 Wireless Card Replacement: 步骤 2 中的图像 2,3 Dell XPS 15 9570 Wireless Card Replacement: 步骤 2 中的图像 3,3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: 步骤 3 中的图像 1,2 Dell XPS 15 9570 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Flip open the system badge and with a Phillips #00, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 1,2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 2,2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: 步骤 7 中的图像 1,2 Dell XPS 15 9570 Wireless Card Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the wireless card.
结论
Margaret Combs
于09/08/21注册
450 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 94
总计 1,204
