跳转到主内容
Dell XPS 15 9570 Speaker Replacement
你所需要的
  1. Dell XPS 15 9570 Speaker Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Speaker Replacement: 步骤 2 中的图像 1,3 Dell XPS 15 9570 Speaker Replacement: 步骤 2 中的图像 2,3 Dell XPS 15 9570 Speaker Replacement: 步骤 2 中的图像 3,3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Speaker Replacement: 步骤 3 中的图像 1,2 Dell XPS 15 9570 Speaker Replacement: 步骤 3 中的图像 2,2
    • Flip open the system badge and with a Phillips #00, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Speaker Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Speaker Replacement, Battery: 步骤 5 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Speaker Replacement: 步骤 6 中的图像 1,1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Speaker Replacement: 步骤 7 中的图像 1,1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Speaker Replacement, Speaker: 步骤 8 中的图像 1,2 Dell XPS 15 9570 Speaker Replacement, Speaker: 步骤 8 中的图像 2,2
    • Using the iFixit opening tool, disconnect the speaker cable by pulling it out gently.
  9. Dell XPS 15 9570 Speaker Replacement: 步骤 9 中的图像 1,3 Dell XPS 15 9570 Speaker Replacement: 步骤 9 中的图像 2,3 Dell XPS 15 9570 Speaker Replacement: 步骤 9 中的图像 3,3
    • Remove the four 2 mm screws using the Philips #00 screwdriver.
    • There are two on the left speaker and two on the right.
    • Follow the images for the right side to complete the left side as well.
  10. Dell XPS 15 9570 Speaker Replacement: 步骤 10 中的图像 1,1
    • Remove the speakers from the back of the computer.
结论
另外一个人完成了本指南。
Margaret Combs
于09/08/21注册
450 声望
创作了4篇指南
团队
一条评论
Thank you for the tutorial!
Just did the swap with speakers form a DELL XPS 15 from an unknown model (most likely wasn't a 9570). Note that these speakers are common inbetween different XPS 15 models (at least XPS 9550 9560 M5510 9350 5520 5510 and Precision 5510 5520 5530 5540 PK23000RP00 TX47W 0TX47W) ******and can be interchanged.
The ones I just used were salvaged from an out-of-service XPS 15 but the parts can be sourced online easily (ex: https://www.amazon.com/Deal4GO-Speaker-R... )
Cheers
Antalog - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 114
总计 1,047
