简介
You can use this guide to learn the steps to remove the motherboard of your Dell XPS 15 9570. The motherboard generates a network between all major components of the system. A faulty or broken motherboard prevents any use of the computer.
Prior to starting this guide, be sure the laptop is powered off and it is unplugged from the charging cord.
你所需要的
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
Disconnect the two motherboard cables located on the bottom of the motherboard using the opening tool.
另外一个人完成了本指南。
