跳转到主内容
Dell XPS 15 9570 Motherboard Replacement
你所需要的
  1. Dell XPS 15 9570 Motherboard Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Motherboard Replacement: 步骤 2 中的图像 1,3 Dell XPS 15 9570 Motherboard Replacement: 步骤 2 中的图像 2,3 Dell XPS 15 9570 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Motherboard Replacement: 步骤 3 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Motherboard Replacement, Battery: 步骤 5 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Motherboard Replacement: 步骤 7 中的图像 1,1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Motherboard Replacement, Heat Sink: 步骤 8 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement, Heat Sink: 步骤 8 中的图像 2,2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Motherboard Replacement, Fan: 步骤 10 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement, Fan: 步骤 10 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Motherboard Replacement: 步骤 12 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Motherboard Replacement, RAM: 步骤 14 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement, RAM: 步骤 14 中的图像 2,2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Motherboard Replacement, SSD: 步骤 16 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement, SSD: 步骤 16 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Motherboard Replacement: 步骤 17 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Motherboard Replacement, Wireless Card: 步骤 18 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement, Wireless Card: 步骤 18 中的图像 2,2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Motherboard Replacement: 步骤 19 中的图像 1,1
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Motherboard Replacement: 步骤 20 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement: 步骤 20 中的图像 2,2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Motherboard Replacement: 步骤 21 中的图像 1,1
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Motherboard Replacement, Motherboard: 步骤 22 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement, Motherboard: 步骤 22 中的图像 2,2
    • Disconnect the two motherboard cables located on the bottom of the motherboard using the opening tool.
  23. Dell XPS 15 9570 Motherboard Replacement: 步骤 23 中的图像 1,3 Dell XPS 15 9570 Motherboard Replacement: 步骤 23 中的图像 2,3 Dell XPS 15 9570 Motherboard Replacement: 步骤 23 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  24. Dell XPS 15 9570 Motherboard Replacement: 步骤 24 中的图像 1,3 Dell XPS 15 9570 Motherboard Replacement: 步骤 24 中的图像 2,3 Dell XPS 15 9570 Motherboard Replacement: 步骤 24 中的图像 3,3
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  25. Dell XPS 15 9570 Motherboard Replacement: 步骤 25 中的图像 1,2 Dell XPS 15 9570 Motherboard Replacement: 步骤 25 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
结论
另外一个人完成了本指南。
团队
IUPUI, Team 3-1, Harley Fall 2023 IUPUI, Team 3-1, Harley Fall 2023 的会员
IUPUI-HARLEY-F23S3G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 14
过去 30 天: 71
总计 462
