跳转到主内容
Dell XPS 15 9570 Fan Replacement
你所需要的
  1. Dell XPS 15 9570 Fan Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Fan Replacement: 步骤 2 中的图像 1,3 Dell XPS 15 9570 Fan Replacement: 步骤 2 中的图像 2,3 Dell XPS 15 9570 Fan Replacement: 步骤 2 中的图像 3,3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Fan Replacement: 步骤 3 中的图像 1,2 Dell XPS 15 9570 Fan Replacement: 步骤 3 中的图像 2,2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Fan Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Fan Replacement, Battery: 步骤 5 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Fan Replacement: 步骤 6 中的图像 1,1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Fan Replacement: 步骤 7 中的图像 1,1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Fan Replacement, Fan: 步骤 8 中的图像 1,2 Dell XPS 15 9570 Fan Replacement, Fan: 步骤 8 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  9. Dell XPS 15 9570 Fan Replacement: 步骤 9 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  10. Dell XPS 15 9570 Fan Replacement: 步骤 10 中的图像 1,2 Dell XPS 15 9570 Fan Replacement: 步骤 10 中的图像 2,2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  11. Dell XPS 15 9570 Fan Replacement: 步骤 11 中的图像 1,1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
结论
Clay Caldwell
于09/03/21注册
357 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 43
过去 30 天: 137
总计 5,336
