跳转到主内容
Dell XPS 15 9560 Touchpad Replacement
你所需要的
  1. Dell XPS 15 9560 Touchpad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Touchpad Replacement: 步骤 3 中的图像 1,1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Touchpad Replacement, Battery: 步骤 4 中的图像 1,1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Touchpad Replacement: 步骤 5 中的图像 1,1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Touchpad Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
  7. Dell XPS 15 9560 Touchpad Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Touchpad Replacement, Trackpad: 步骤 9 中的图像 1,1
    • Shutdown & unplug your laptop.
  10. Dell XPS 15 9560 Touchpad Replacement: 步骤 10 中的图像 1,1
    • Remove the two 5 mm mounting screws for the touchpad.
  11. Dell XPS 15 9560 Touchpad Replacement: 步骤 11 中的图像 1,1
    • Remove the 5mm screw to allow removal of the plate.
  12. Dell XPS 15 9560 Touchpad Replacement: 步骤 12 中的图像 1,1
    • Unplug the small cord from its slot on the board.
  13. Dell XPS 15 9560 Touchpad Replacement: 步骤 13 中的图像 1,2 Dell XPS 15 9560 Touchpad Replacement: 步骤 13 中的图像 2,2
    • Unplug the black cord from the board.
    • Unplug the cord with a white plug from the board.
  14. Dell XPS 15 9560 Touchpad Replacement: 步骤 14 中的图像 1,2 Dell XPS 15 9560 Touchpad Replacement: 步骤 14 中的图像 2,2
    • Gently pull the white ribbon cables loose from their housings.
  15. Dell XPS 15 9560 Touchpad Replacement: 步骤 15 中的图像 1,1
    • Lift the laptop so it's in the open position as shown.
    • Push the touchpad free from the keyboard side of the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 40
过去 30 天: 168
总计 3,454
