跳转到主内容
Dell XPS 15 9560 Motherboard Replacement
你所需要的
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Motherboard Replacement, Battery: 步骤 4 中的图像 1,1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
  7. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): 步骤 9 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  10. Dell XPS 15 9560 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  12. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: 步骤 12 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  13. Dell XPS 15 9560 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Disconnect the wireless card cables from the wireless card.
  14. Dell XPS 15 9560 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Slide the wireless card out of its slot.
  15. Dell XPS 15 9560 Motherboard Replacement, Fans: 步骤 15 中的图像 1,1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  16. Dell XPS 15 9560 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Unplug the fan cable.
  17. Dell XPS 15 9560 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Carefully remove the left-side fan.
  18. Dell XPS 15 9560 Motherboard Replacement: 步骤 18 中的图像 1,1
  19. Dell XPS 15 9560 Motherboard Replacement: 步骤 19 中的图像 1,1
    • Remove the right-side fan.
  20. Dell XPS 15 9560 Motherboard Replacement, RAM: 步骤 20 中的图像 1,2 Dell XPS 15 9560 Motherboard Replacement, RAM: 步骤 20 中的图像 2,2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  21. Dell XPS 15 9560 Motherboard Replacement, Motherboard: 步骤 21 中的图像 1,1
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  22. Dell XPS 15 9560 Motherboard Replacement: 步骤 22 中的图像 1,1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  23. Dell XPS 15 9560 Motherboard Replacement: 步骤 23 中的图像 1,1
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  24. Dell XPS 15 9560 Motherboard Replacement: 步骤 24 中的图像 1,1
    • Remove the motherboard.
结论
Jada Houser
于09/28/21注册
790 声望
创作了7篇指南
团队
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G5
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 78
总计 3,827
