跳转到主内容
Dell XPS 15 9550 Wireless Card Replacement
你所需要的
  1. Dell XPS 15 9550 Wireless Card Replacement, Back/Underside Panel: 步骤 1 中的图像 1,1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Wireless Card Replacement: 步骤 2 中的图像 1,2 Dell XPS 15 9550 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Wireless Card Replacement: 步骤 3 中的图像 1,3 Dell XPS 15 9550 Wireless Card Replacement: 步骤 3 中的图像 2,3 Dell XPS 15 9550 Wireless Card Replacement: 步骤 3 中的图像 3,3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
    • Set the screw and metal holder aside.
  5. Dell XPS 15 9550 Wireless Card Replacement: 步骤 5 中的图像 1,2 Dell XPS 15 9550 Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Gently lift up each of the antennas (3) to disconnect them from the wireless card.
    • These are similar to a coat button, the antennas snap on and snap off.
  6. Dell XPS 15 9550 Wireless Card Replacement: 步骤 6 中的图像 1,3 Dell XPS 15 9550 Wireless Card Replacement: 步骤 6 中的图像 2,3 Dell XPS 15 9550 Wireless Card Replacement: 步骤 6 中的图像 3,3
    • With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
    • The wireless card has been successfully removed!
结论
4等其他人完成本指南。
Hunter J Laska
于10/04/18注册
157 声望
撰写一个指南
团队
UW Stout, Team S6-G1, Ogden Fall 2018 UW Stout, Team S6-G1, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G1
4 名成员
创作了23篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 62
总计 9,614
