跳转到主内容
Dell XPS 15 9530 WiFi Card Replacement
你所需要的
  1. Dell XPS 15 9530 WiFi Card Replacement, Base Cover: 步骤 1 中的图像 1,3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: 步骤 1 中的图像 2,3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: 步骤 1 中的图像 3,3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 WiFi Card Replacement: 步骤 2 中的图像 1,2 Dell XPS 15 9530 WiFi Card Replacement: 步骤 2 中的图像 2,2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 WiFi Card Replacement: 步骤 3 中的图像 1,1
    • Lift the lower case off.
  4. Dell XPS 15 9530 WiFi Card Replacement, WiFi Card: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the screw holding the WiFi card down. Be careful not to lose the metal retainer holding the antenna cables down.
    • Without applying too much force, pop out the antenna cables and remove the card.
    • Insert the new card, and reattach the antenna cables. The black cable connects to the main antenna slot (marked with a solid triangle) and the white connects to the auxiliary (marked with an empty triangle).
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 46
总计 1,726
