简介
Removal of the touch pad will be covered in this guide. To successfully remove the battery, a #0 Phillips screwdriver, a T5 Torx screwdriver, and a plastic spudger are needed. Be careful disconnecting cables as to not break them or their connectors.
你所需要的
Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
Remove the touch pad ribbon cable by lifting the small plastic flap and pulling ribbon straight out of the connector.
另外一个人完成了本指南。
