简介
How to replace the 2.5" hard drive of a Dell XPS 15 9530.
你所需要的
步骤 1 Unscrewing the Base-Cover Assembly
注意:步骤 1-2 源自标记为进行中的 指南。
After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
步骤 3 Remove Battery
注意:步骤 3 源自标记为进行中的 指南。
Remove the screws that secure the battery to the palm-rest assembly.
Disconnect the battery cable from the system board.
Lift the battery off the palm-rest assembly.
Remove the screws that secure the hard-drive assembly to the palm-rest assembly.
Using the pull tab, disconnect the hard-drive cable from the system board.
Lift the hard-drive assembly off the palm-rest assembly.
Disconnect the interposer from the hard-drive assembly.
Remove the screws that secure the hard-drive bracket to the hard drive.
Lift the hard drive off the hard-drive bracket.
To reassemble your device, follow these instructions in reverse order with the replacement hard drive.
2等其他人完成本指南。
