跳转到主内容
Dell XPS 15 9510 Headphone Jack Replacement
你所需要的
  1. Dell XPS 15 9510 Headphone Jack Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 1,2 Dell XPS 15 9510 Headphone Jack Replacement, Headphone Jack: 步骤 4 中的图像 2,2
    • Remove three screws connecting the headphone jack to the back panel using a Phillips #00 screwdriver.
  5. Dell XPS 15 9510 Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the headphone jack off the removed panel.
结论
Austin Sa
于03/30/22注册
432 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-3, Mellen Spring 2022 UMass Dartmouth, Team 1-3, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 1,115
