简介
Replacing the battery of a Dell XPS 15 9510 laptop is a straightforward task requiring only a few tools. The new battery constitutes nearly all of the cost of this repair, so if you are planning to order a replacement battery for this or any other laptop, it may be wise to remove the back panel of the laptop to ensure that the one you are ordering matches the existing one.
If the battery you are replacing is swollen, be sure to take appropriate precautions.
你所需要的
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Using the small battery pull tab, disconnect the battery connector from the motherboard.
4等其他人完成本指南。
