跳转到主内容
Dell XPS 15 9500 Speaker Replacement
你所需要的
  1. Dell XPS 15 9500 Speaker Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Speaker Replacement: 步骤 2 中的图像 1,2 Dell XPS 15 9500 Speaker Replacement: 步骤 2 中的图像 2,2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 3.0 mm screws (one on each speaker).
    • Use an opening tool to lift out the speaker.
  4. Dell XPS 15 9500 Speaker Replacement: 步骤 4 中的图像 1,2 Dell XPS 15 9500 Speaker Replacement: 步骤 4 中的图像 2,2
    • Use an opening tool to push the left speaker's cable out of its port until it is disconnected.
    • The speaker on the right side isn't connected to the motherboard, and is only connected to the left speaker by a wire at the bottom.
结论
Bryan Chung
于10/18/19注册
437 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 32
总计 850
