跳转到主内容
Dell XPS 15 9500 SSD Replacement
你所需要的
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: 步骤 2 中的图像 1,2 Dell XPS 15 9500 SSD Replacement: 步骤 2 中的图像 2,2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: 步骤 3 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: 步骤 4 中的图像 1,1
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: 步骤 5 中的图像 1,2 Dell XPS 15 9500 SSD Replacement: 步骤 5 中的图像 2,2
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
结论
Bryan Chung
于10/18/19注册
437 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 32
过去 30 天: 128
总计 4,104
