跳转到主内容
Dell XPS 14Z L412Z LCD Screen Glass Replacement
你所需要的
  1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: 步骤 1 中的图像 1,2 Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: 步骤 1 中的图像 2,2
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Dell XPS 14Z L412Z LCD Screen Glass Replacement: 步骤 2 中的图像 1,2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: 步骤 2 中的图像 2,2
    • Using a heat gun, carefully apply heat evenly across the glass.
  3. Dell XPS 14Z L412Z LCD Screen Glass Replacement: 步骤 3 中的图像 1,2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: 步骤 3 中的图像 2,2
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
结论
Colton Niewolny
于02/15/18注册
411 声望
创作了4篇指南
团队
UW Stout, Team S8-G3, Ogden Spring 2018 UW Stout, Team S8-G3, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G3
4 名成员
创作了6篇指南
一条评论
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 2,152
