跳转到主内容
Dell XPS 14Z L412Z Hard Drive Replacement
你所需要的
  1. Dell XPS 14Z L412Z Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell XPS 14Z L412Z Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Locate the hard drive on the bottom right corner.
    • Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
  4. Dell XPS 14Z L412Z Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the four additional 3.5mm screws using the Phillips #0 screwdriver.
  5. Dell XPS 14Z L412Z Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Carefully pull and remove the old hard drive.
结论
Colton Niewolny
于02/15/18注册
411 声望
创作了4篇指南
团队
UW Stout, Team S8-G3, Ogden Spring 2018 UW Stout, Team S8-G3, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G3
4 名成员
创作了6篇指南
一条评论
On my laptop there was a small curved metal bracket that sat in the very corner of the PC covering one corner of the hard drive. That had to be removed by loosening a screw and gently prying the bar out before the hard drive could be removed.
dude - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 1,582
