跳转到主内容
Dell XPS 14Z L412Z Battery Replacement
你所需要的
  1. Dell XPS 14Z L412Z Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Battery Replacement: 步骤 2 中的图像 1,2 Dell XPS 14Z L412Z Battery Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • The battery is on the bottom left side.
  4. Dell XPS 14Z L412Z Battery Replacement: 步骤 4 中的图像 1,1
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Dell XPS 14Z L412Z Battery Replacement: 步骤 5 中的图像 1,2 Dell XPS 14Z L412Z Battery Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
结论
4等其他人完成本指南。
Colton Niewolny
于02/15/18注册
411 声望
创作了4篇指南
团队
UW Stout, Team S8-G3, Ogden Spring 2018 UW Stout, Team S8-G3, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G3
4 名成员
创作了6篇指南
一条评论
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 2,925
