跳转到主内容
Dell XPS 14 L401X RAM Replacement
你所需要的
  1. Dell XPS 14 L401X RAM Replacement, Battery: 步骤 1 中的图像 1,2 Dell XPS 14 L401X RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X RAM Replacement, RAM: 步骤 2 中的图像 1,3 Dell XPS 14 L401X RAM Replacement, RAM: 步骤 2 中的图像 2,3 Dell XPS 14 L401X RAM Replacement, RAM: 步骤 2 中的图像 3,3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X RAM Replacement: 步骤 3 中的图像 1,2 Dell XPS 14 L401X RAM Replacement: 步骤 3 中的图像 2,2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
结论
To replace the RAM, put the RAM in the now empty socket and push down on spring clips. Then replace the panel by following the instructions in reverse order.
Nicole Johnson
于10/19/17注册
443 声望
创作了4篇指南
团队
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G3
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 368
