跳转到主内容
Dell XPS 14 L401X Optical Drive Replacement
你所需要的
  1. Dell XPS 14 L401X Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell XPS 14 L401X Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Optical Drive Replacement, RAM: 步骤 2 中的图像 1,3 Dell XPS 14 L401X Optical Drive Replacement, RAM: 步骤 2 中的图像 2,3 Dell XPS 14 L401X Optical Drive Replacement, RAM: 步骤 2 中的图像 3,3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Optical Drive Replacement: 步骤 3 中的图像 1,2 Dell XPS 14 L401X Optical Drive Replacement: 步骤 3 中的图像 2,2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,2 Dell XPS 14 L401X Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 2,2
    • Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
  5. Dell XPS 14 L401X Optical Drive Replacement: 步骤 5 中的图像 1,3 Dell XPS 14 L401X Optical Drive Replacement: 步骤 5 中的图像 2,3 Dell XPS 14 L401X Optical Drive Replacement: 步骤 5 中的图像 3,3
    • Carefully pull out the optical drive from its bay.
  6. Dell XPS 14 L401X Optical Drive Replacement: 步骤 6 中的图像 1,2 Dell XPS 14 L401X Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Carefully pull off the decorative cover from the front of the optical drive.
    • This decorative cover will be transferred to the new optical drive.
  7. Dell XPS 14 L401X Optical Drive Replacement: 步骤 7 中的图像 1,3 Dell XPS 14 L401X Optical Drive Replacement: 步骤 7 中的图像 2,3 Dell XPS 14 L401X Optical Drive Replacement: 步骤 7 中的图像 3,3
    • Use a JIS 1 screwdriver to remove (2) 2mm screws on the drive's anchoring bracket.
    • This bracket will be transferred to the new optical drive.
结论
Mark
于10/19/17注册
655 声望
创作了6篇指南
团队
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G3
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 367
