简介
Hard drives can sometimes experience hardware failure and need to be replaced, or you may just want to upgrade. This guide will show you how to remove the hard drive from the laptop and detach the cosmetic cover to replace the hard drive.
你所需要的
Locate the spring latch on the bottom of the device that will unlatch the battery.
Hold the spring latch in the open position and pull the battery out of its recess.
Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
即将完成!
结论
