跳转到主内容
Dell XPS 1340 CPU Fan Replacement
你所需要的
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: 步骤 1 中的图像 1,1
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: 步骤 3 中的图像 1,1
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: 步骤 4 中的图像 1,2 Dell XPS 1340 CPU Fan Replacement: 步骤 4 中的图像 2,2
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: 步骤 5 中的图像 1,2 Dell XPS 1340 CPU Fan Replacement: 步骤 5 中的图像 2,2
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: 步骤 6 中的图像 1,1
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
结论
4等其他人完成本指南。
Paras Tolani
于03/01/13注册
188 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,790
