当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
将电池电缆连接器拉向电池以将其与插座断开。
如果连接器很顽固,请在一侧轻轻推一下,然后在另一侧推,让它从插座中“走”出来。
如果你无法将连接器从插座中取出,请使用撬棒尖轻轻推动连接器凹口,将连接器滑出。
打开显示屏并按住电源按钮五秒钟以耗尽系统中的所有剩余电量。
16等其他人完成本指南。
一条评论
Thanks for the instructions on swapping out the WiFi module/chip, it looked pretty straightforward from what I could tell when I had the machine open, I just have a simple question for you.
I recently purchased an Intel Dual Band Wireless -AC 8265 Desktop Kit and I do NOT plan on using the external antenna, or mounting bracket that came with it, ONLY the chip in place of the one on the laptop.
So I wanted to know would the chip in that kit be useable in my Dell XPS 13 9343 model laptop? Everything looks to be about the same with this chip and the actual laptop model [except that the laptop one doesn’t come with the external antenna], so if I can use it that would save me shipping it back and then ordering again.
Thanks
