跳转到主内容
  1. Remove eight T5 Torx screws Remove a Philips screw under the plastic tab Remove a Philips screw under the plastic tab
    • Remove eight T5 Torx screws
    • Remove a Philips screw under the plastic tab
  2. Use opening picks to open the lower case Use opening picks to open the lower case
    • Use opening picks to open the lower case
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Disconnect the battery and move the battery cable out of the way Disconnect the battery and move the battery cable out of the way
    • Disconnect the battery and move the battery cable out of the way
  5. Remove a Philips screw Use a pair of tweezers to remove a metal clamp holding the wireless card Use a spudger to disconnect a couple of antenna cables
    • Use a pair of tweezers to remove a metal clamp holding the wireless card
    • Use a spudger to disconnect a couple of antenna cables
    • Pull the wireless card parallel to the motherboard
    • Do not lift the wireless card upward or risk damaging the wireless card slot
结论
10等其他人完成本指南。
The Raptor
于2016年11月27日注册
4,198 信誉积分
创作了7篇指南
Removing it, all well and good, and don’t get me wrong, helpful. But what about installing the replacement, and especially what tools and how to reconnect the wireless card antenna cables.?
Steven Thibault - 回复
Taking the card is all well and good, and don’t get me wrong, this is helpful for that, but what about the other half, installing the replacement. Especially how to reconnect the wireless cards antenna cables and the tools necessary for that?
This article is incomplete. And it doesn’t address how easy it is to damage the wires connected to the wireless card.
Matthew Coburn - 回复
添加评论
浏览统计数据:
过去的24小时: 8
过去的7天: 40
过去的30天: 228
总计 7,085
