当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
将电池电缆连接器拉向电池以将其与插座断开。
如果连接器很顽固,请在一侧轻轻推一下,然后在另一侧推,让它从插座中“走”出来。
如果你无法将连接器从插座中取出,请使用撬棒尖轻轻推动连接器凹口,将连接器滑出。
打开显示屏并按住电源按钮五秒钟以耗尽系统中的所有剩余电量。
27等其他人完成本指南。
13条评论
I’m kinda new on pc upgrading. So once I install a new m.2 I’ll need to install a new window 10 right
Yes, you have to install windows again. or you can clone your existing ssd onto the new one using some adapters easily found online
You will have to reinstall unless you are buying a samsung m.2 which comes with a disk duplicator utility. The xps 13 cames with a samsung early life evo disk (128GB) and transferring from 1 evo to another is very easy with the app. I believe its the same with every disk though I havent tried the latter.
Dell has some nice recovery tools:
https://www.dell.com/support/kbdoc/en-us...
I downloaded a recovery image to use from a USB drive. I am using it to reinstall the Windows that came with the PC. You don't have to be the original owner but you do need to have the Dell asset number usually stored in the bios
https://www.laptopmag.com/articles/upgra...
helpful resource
