简介
With a huge display packed into a very sleek package, we didn't have high hopes heading into this assessment, but we were pleased to discover an overall lack of adhesive, standard screws, and publically-available repair documentation—all of which contributed to the XPS 13's 7 out of 10.
  1. Packaging and open reference shots.
    • Packaging and open reference shots.
  2. Front and back reference shots.
    • Front and back reference shots.
    • Removing the back cover is straightforward—remove the eight T6 screws and the single Phillips, then pry the back cover off.
    • Internal reference shot.
    • Looks like battery, speakers, CMOS battery, SSD, wi-fi card, DC socket, and daughterboard are easily accessible.
    • There's some tape over the battery so we peel it off before removing the four screws securing it to the lower case.
    • Next out is the SSD and and the wireless card.
      • All the cables we've encountered thus far have some tape on them. Not a ton, but some will need to be replaced unless you're very careful during disassembly.
    • The display connector is a little tricky. It's secured by a bracket and five pieces of tape, but at least had a handy pull-tab to assuage worries about breaking the connector.
    • We go to pull the fan out before the motherboard but its foot is caught in the way.
    • So we remove six motherboard screws and the the thermal management comes right afterwards.
    • Motherboard reference.
    • The trackpad comes out fairly easily—remove four screws and, unfortunately, a bit of tape.
    • Then parts just start flying. After loosening a handful of Phillips screws we can remove the daughterboard (home to a USB port and SD card reader), speakers, RTC battery (which is just glued in place), and the DC-in socket.
    • And after removing a couple dozen more screws, the keyboard comes out with no drama (and no tape!).
    • The display assembly is held in with four Phillips screws and is easy to remove.
    • Before discarding the palmrest, we pull out this small breakout board that drives the keyboard.
      • This particular board is very heavily glued in place, but it's unlikely you'll ever need to remove it.
    • The Dell XPS 13 earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
      • Manufacturer provides free manuals online.
      • Once you manage to take off the bottom cover, all the parts are pretty easily replaceable.
      • Screws and connectors are labeled, aiding reassembly.
      • Moderate adhesive—except for the display assembly, no heat is required to disassemble.
      • The layering could be improved to make certain components easier to remove, but overall the modular design makes repairs cheaper.
      • Soldered RAM means you'll never be able to upgrade when things get slow.
终点
9等其他人完成本指南。
Evan Noronha
于2015年02月05日注册
152,449 信誉积分
创作了176篇指南
团队
iFixit iFixit 的会员
Community
108 名成员
创作了7,542篇指南
浏览统计数据:
过去的24小时: 6
过去的7天: 77
过去的30天: 381
总计 6,421
