简介
How to replace the mSata SSD drive in a Dell XPS 13 L322X laptop. The images and information in this guide were taken from this computer's service manual, which can be found on the product page.
  1. After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • Using a prying tool or a fingernail, lift up the base cover (#1).
  2. Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • After removing the Philips screw which holds down the power-light board (#1), remove the power light board (#2) and its cable.
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Peel the tape that is adhered over the solid-state drive.
    • Peel the tape that is adhered over the solid-state drive.
  5. Remove the screw that secures the solid-state drive to the system board.
    • Remove the screw that secures the solid-state drive to the system board.
    • Slide and remove the solid-state drive out of the system-board connector.
  6. Align the notch on the NEW solid-state drive with the tab in the system-board connector.
    • Align the notch on the NEW solid-state drive with the tab in the system-board connector.
    • CAUTION: Use firm and even pressure to slide the solid-state drive into place. If you use excessive force, you may damage the connector.
    • Insert the solid-state drive connector at a 45-degree angle into the system-board connector.
    • Replace the screw that secures the solid-state drive to the system board.
  7. Adhere the tape over the solid-state drive.
    • Adhere the tape over the solid-state drive.
结论
To reassemble your device, reattatch the power board cable and screw back on the base cover.
Johnathan Hammond
于2018年02月28日注册
35,786 信誉积分
创作了408篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
15 名成员
创作了925篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 18
总计 351
