当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
将电池电缆连接器拉向电池以将其与插座断开。
如果连接器很顽固,请在一侧轻轻推一下,然后在另一侧推,让它从插座中“走”出来。
如果你无法将连接器从插座中取出,请使用撬棒尖轻轻推动连接器凹口,将连接器滑出。
打开显示屏并按住电源按钮五秒钟以耗尽系统中的所有剩余电量。
5等其他人完成本指南。
3条评论
Great guide! The two hardest parts were getting the back cover off, and lifting the motherboard to remove the fan. Took me about 30 minutes in total.
It would be really easier if you remove the battery screws first… there are some steps that were not clear…
This repair took me about 45 min for a complete novice. “Walking out” the battery connector was only way I could unplug it. There was a retaining bracket overlaying the flat connector (step 8) that I needed to unscrew (2 screws, phillips) before it could be removed. Take care to replace the wire in the wire guides along the fan’s housing prior to reinsertion of the replacement fan. It cannot be done afterwards and the back panel will not be flush. Otherwise, this was an excellent guide and an easy repair.
