跳转到主内容
Dell XPS 13 Fan Replacement
你所需要的
  1. Dell XPS 13 Fan Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell XPS 13 Fan Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Fan Replacement: 步骤 2 中的图像 1,2 Dell XPS 13 Fan Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Fan Replacement: 步骤 3 中的图像 1,1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Fan Replacement: 步骤 4 中的图像 1,1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover.
  6. Dell XPS 13 Fan Replacement, Battery Disconnection: 步骤 6 中的图像 1,2 Dell XPS 13 Fan Replacement, Battery Disconnection: 步骤 6 中的图像 2,2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Fan Replacement, Fan: 步骤 7 中的图像 1,3 Dell XPS 13 Fan Replacement, Fan: 步骤 7 中的图像 2,3 Dell XPS 13 Fan Replacement, Fan: 步骤 7 中的图像 3,3
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Dell XPS 13 Fan Replacement: 步骤 8 中的图像 1,2 Dell XPS 13 Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Dell XPS 13 Fan Replacement: 步骤 9 中的图像 1,2 Dell XPS 13 Fan Replacement: 步骤 9 中的图像 2,2
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Dell XPS 13 Fan Replacement: 步骤 10 中的图像 1,2 Dell XPS 13 Fan Replacement: 步骤 10 中的图像 2,2
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
结论
5等其他人完成本指南。
Ella Herrmann
于04/24/17注册
1,588 声望
创作了3篇指南
团队
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G6
5 名成员
创作了30篇指南
3条评论
Great guide! The two hardest parts were getting the back cover off, and lifting the motherboard to remove the fan. Took me about 30 minutes in total.
John Reeder - 回复
It would be really easier if you remove the battery screws first… there are some steps that were not clear…
Nicolás Jiménez Bautista - 回复
This repair took me about 45 min for a complete novice. “Walking out” the battery connector was only way I could unplug it. There was a retaining bracket overlaying the flat connector (step 8) that I needed to unscrew (2 screws, phillips) before it could be removed. Take care to replace the wire in the wire guides along the fan’s housing prior to reinsertion of the replacement fan. It cannot be done afterwards and the back panel will not be flush. Otherwise, this was an excellent guide and an easy repair.
Scott Freeman - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 52
过去 30 天: 253
总计 21,895
