跳转到主内容
Dell XPS 13 9370 Battery Replacement
你所需要的
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: 步骤 2 中的图像 1,1
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: 步骤 3 中的图像 1,2 Dell XPS 13 9370 Battery Replacement, Remove the base cover: 步骤 3 中的图像 2,2
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: 步骤 4 中的图像 1,1
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: 步骤 5 中的图像 1,1
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
结论
To replace the battery & reassemble your device, follow these instructions in reverse order.
23等其他人完成本指南。
Max Kletskov
于04/22/20注册
40,307 声望
创作了16篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,267篇指南
8条评论
Is the battery an original dell battery?
mnyousafva - 回复
Why doesn’t it say what tools are needed?
Noah Guirguis - 回复
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - 回复
Instructions were perfect, thanks for the great guide!
surfdaworld - 回复
Boom, in a good way! I fixed it!
Chris Cox - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 125
过去 30 天: 511
总计 15,379
