跳转到主内容
Dell XPS 13 9365 2-in-1 Touchpad Replacement
你所需要的
  1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 3 中的图像 1,1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: 步骤 8 中的图像 1,3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: 步骤 8 中的图像 2,3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: 步骤 8 中的图像 3,3
    • Open the ZIF latch on the touch pad connector.
    • Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
  9. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the two screws (M2x2) that secure the touch pad to the palm-rest assembly.
  10. Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 10 中的图像 1,2 Dell XPS 13 9365 2-in-1 Touchpad Replacement: 步骤 10 中的图像 2,2
    • Lift the touch pad from the inner edge and remove it from the palm-rest assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 9
过去 30 天: 21
总计 628
