跳转到主内容
Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement
你所需要的
  1. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 2 中的图像 1,1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 3 中的图像 1,1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 7 中的图像 1,1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Removing the Solid-State Drive: 步骤 8 中的图像 1,1
    • Peel off the display cable tape from the hard-drive plate.
  9. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the two screws (M1.6x2.5) that secure the hard-drive plate to the system board with a Phillips 000 screwdriver head.
  10. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 10 中的图像 1,1
    • Remove the hard-drive plate.
  11. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: 步骤 11 中的图像 1,1
    • Gently slide and remove the solid-state drive from the solid-state drive slot (SSD not pictured in image).
    • Solid-state drives are fragile. Exercise care when handling the solid-state drive.
结论
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
44,953 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 51
总计 5,993
