跳转到主内容
Dell XPS 13 Track Pad Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Dell XPS 13 Track Pad Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell XPS 13 Track Pad Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Track Pad Replacement: 步骤 2 中的图像 1,2 Dell XPS 13 Track Pad Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Track Pad Replacement: 步骤 3 中的图像 1,1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Track Pad Replacement: 步骤 4 中的图像 1,1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Track Pad Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover.
  6. Dell XPS 13 Track Pad Replacement, Battery Disconnection: 步骤 6 中的图像 1,2 Dell XPS 13 Track Pad Replacement, Battery Disconnection: 步骤 6 中的图像 2,2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Track Pad Replacement, Battery: 步骤 7 中的图像 1,2 Dell XPS 13 Track Pad Replacement, Battery: 步骤 7 中的图像 2,2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  8. Dell XPS 13 Track Pad Replacement: 步骤 8 中的图像 1,2 Dell XPS 13 Track Pad Replacement: 步骤 8 中的图像 2,2
    • Do not pull up.
  9. Dell XPS 13 Track Pad Replacement: 步骤 9 中的图像 1,1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Dell XPS 13 Track Pad Replacement: 步骤 10 中的图像 1,1
    • Remove the battery.
  11. Dell XPS 13 Track Pad Replacement, Track Pad: 步骤 11 中的图像 1,2 Dell XPS 13 Track Pad Replacement, Track Pad: 步骤 11 中的图像 2,2
    • Remove the four 3 mm Phillips #1 screws from the trackpad.
  12. Dell XPS 13 Track Pad Replacement: 步骤 12 中的图像 1,1
    • Use tweezers to gently lift the upper-right corner of the track pad.
    • Remove the track pad by slowly pulling it up and away from you.
结论
4等其他人完成本指南。
Arvind Krish
于04/26/17注册
179 声望
撰写一个指南
团队
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G6
5 名成员
创作了30篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 124
总计 13,257
