跳转到主内容
Dell XPS 13 Display Assembly Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Dell XPS 13 Display Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell XPS 13 Display Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Display Assembly Replacement: 步骤 2 中的图像 1,2 Dell XPS 13 Display Assembly Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover.
  6. Dell XPS 13 Display Assembly Replacement, Battery Disconnection: 步骤 6 中的图像 1,2 Dell XPS 13 Display Assembly Replacement, Battery Disconnection: 步骤 6 中的图像 2,2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Display Assembly Replacement, Battery: 步骤 7 中的图像 1,2 Dell XPS 13 Display Assembly Replacement, Battery: 步骤 7 中的图像 2,2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  8. Dell XPS 13 Display Assembly Replacement: 步骤 8 中的图像 1,2 Dell XPS 13 Display Assembly Replacement: 步骤 8 中的图像 2,2
    • Do not pull up.
  9. Dell XPS 13 Display Assembly Replacement: 步骤 9 中的图像 1,1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Dell XPS 13 Display Assembly Replacement: 步骤 10 中的图像 1,1
    • Remove the battery.
  11. Dell XPS 13 Display Assembly Replacement, Display Assembly: 步骤 11 中的图像 1,3 Dell XPS 13 Display Assembly Replacement, Display Assembly: 步骤 11 中的图像 2,3 Dell XPS 13 Display Assembly Replacement, Display Assembly: 步骤 11 中的图像 3,3
    • Pull the sliding touchscreen connector gently to the right and out of the motherboard.
  12. Dell XPS 13 Display Assembly Replacement: 步骤 12 中的图像 1,2 Dell XPS 13 Display Assembly Replacement: 步骤 12 中的图像 2,2
    • Use your fingers to remove the sliding camera connector out from the motherboard.
  13. Dell XPS 13 Display Assembly Replacement: 步骤 13 中的图像 1,2 Dell XPS 13 Display Assembly Replacement: 步骤 13 中的图像 2,2
    • Pop the coaxial antenna cables up from the wireless card with the flat end of the spudger.
  14. Dell XPS 13 Display Assembly Replacement: 步骤 14 中的图像 1,3 Dell XPS 13 Display Assembly Replacement: 步骤 14 中的图像 2,3 Dell XPS 13 Display Assembly Replacement: 步骤 14 中的图像 3,3
    • Using a spudger, pry up the press fit connector on the end of the left cable bundle.
    • Gently remove the sliding cable connector from its port to the left of the fan.
  15. Dell XPS 13 Display Assembly Replacement: 步骤 15 中的图像 1,3 Dell XPS 13 Display Assembly Replacement: 步骤 15 中的图像 2,3 Dell XPS 13 Display Assembly Replacement: 步骤 15 中的图像 3,3
    • Remove the four, black 4.6 mm screws from the display mounts using a Phillips #0 screwdriver.
    • The laptop needs to be open for the display to clear the cutouts of the bottom case, so you may find it easier to remove the screws while already in an open configuration.
    • Remove the display assembly.
结论
10等其他人完成本指南。
Austin Blakely
于03/11/19注册
19,479 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,732篇指南
2条评论
After disassembling the screen, how do I peel it off the metal screen cover?
Jon - 回复
I need to find out what screen model I have to buy a display controller to re-use the screen on a different project, but I’m not able to see behind the screen to find out the exact model.
Jon - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 92
过去 30 天: 399
总计 27,557
