跳转到主内容
Dell XPS 12 9Q33 Battery Replacement
你所需要的
  1. 注意:步骤 1-3 源自标记为进行中的 指南
    Dell XPS 12 9Q33 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
  2. Dell XPS 12 9Q33 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
  3. Dell XPS 12 9Q33 Battery Replacement: 步骤 3 中的图像 1,1
    • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
    • Carefully lift the base cover around the power switch and remove the cover.
  4. Dell XPS 12 9Q33 Battery Replacement, Removing the Battery: 步骤 4 中的图像 1,1
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
结论
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
44,830 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 1,085
