跳转到主内容
Dell XPS 12 9Q23 Touch Pad Replacement
你所需要的
  1. Dell XPS 12 9Q23 Touch Pad Replacement, Battery: 步骤 1 中的图像 1,1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Touch Pad Replacement: 步骤 2 中的图像 1,1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Touch Pad Replacement: 步骤 3 中的图像 1,1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Touch Pad Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Touch Pad Replacement, Remove the battery: 步骤 5 中的图像 1,1
    • Once all the screws have been removed the battery is now safe to extract
  6. Dell XPS 12 9Q23 Touch Pad Replacement, Touch Pad: 步骤 6 中的图像 1,1
    • Unplug the trackpad cable.
  7. Dell XPS 12 9Q23 Touch Pad Replacement: 步骤 7 中的图像 1,1
    • Insert wisdom here.
  8. Dell XPS 12 9Q23 Touch Pad Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips screwdriver to remove the 4 trackpad screws.
  9. Dell XPS 12 9Q23 Touch Pad Replacement: 步骤 9 中的图像 1,1
    • Remove the trackpad.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,637
