跳转到主内容
Dell XPS 12 9Q23 Battery Replacement
你所需要的
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: 步骤 2 中的图像 1,1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Battery Replacement: 步骤 3 中的图像 1,1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: 步骤 5 中的图像 1,1
    • Once all the screws have been removed the battery is now safe to extract
结论
5等其他人完成本指南。
2条评论
Any tips for registering the new battery in the BIOS?
Ryan Porter - 回复
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 31
总计 4,348
