跳转到主内容
加入维修社区 - 创建账户
Dell XPS 10 USB Port Replacement
你所需要的
    1. Dell XPS 10 USB Port Replacement, Battery: 步骤 1 中的图像 1,3 Dell XPS 10 USB Port Replacement, Battery: 步骤 1 中的图像 2,3 Dell XPS 10 USB Port Replacement, Battery: 步骤 1 中的图像 3,3
      • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
      • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
      • Finally, slide the two plastic opening tools all around the case until it is open.
      询问修复机器人
      添加评论
    2. Dell XPS 10 USB Port Replacement: 步骤 2 中的图像 1,3 Dell XPS 10 USB Port Replacement: 步骤 2 中的图像 2,3 Dell XPS 10 USB Port Replacement: 步骤 2 中的图像 3,3
      • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
      • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
      • Unplug the connector the connects the battery to the mother board.
      • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
      询问修复机器人
      添加评论
    1. Dell XPS 10 USB Port Replacement, USB Port: 步骤 3 中的图像 1,3 Dell XPS 10 USB Port Replacement, USB Port: 步骤 3 中的图像 2,3 Dell XPS 10 USB Port Replacement, USB Port: 步骤 3 中的图像 3,3
      • Use the plastic opening tools to lift up the black cable shown in the picture.
      • Slide one end of the speaker to the other side and the speaker will be out.
      询问修复机器人
      添加评论
    2. Dell XPS 10 USB Port Replacement: 步骤 4 中的图像 1,3 Dell XPS 10 USB Port Replacement: 步骤 4 中的图像 2,3 Dell XPS 10 USB Port Replacement: 步骤 4 中的图像 3,3
      • Unscrew the shown screw in the picture.
      • Remove the silver tape using the plastic tool as shown in the picture.
      • Note: be careful when removing the tape as it is fragile.
      询问修复机器人
      添加评论
    3. Dell XPS 10 USB Port Replacement: 步骤 5 中的图像 1,3 Dell XPS 10 USB Port Replacement: 步骤 5 中的图像 2,3 Dell XPS 10 USB Port Replacement: 步骤 5 中的图像 3,3
      • Unscrew the three screws shown in the picture.
      • 3 mm screws.
      • Slide the small piece shown in green square on both black pieces and lift them up using the plastic tool as shown in the picture.
      • Finally, take the USB port out. You will have three pieces out: the port and the two black pieces as shown in the picture.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
James
于10/04/16注册
401 声望
创作了3篇指南
团队
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016 的会员
USFT-NANCE-F16S2G1
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 45
总计 2,304
