跳转到主内容
加入维修社区 - 创建账户
Dell XPS 10 Motherboard Replacement
你所需要的
    1. Dell XPS 10 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Dell XPS 10 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Dell XPS 10 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
      • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
      • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
      • Finally, slide the two plastic opening tools all around the case until it is open.
      询问修复机器人
      添加评论
    2. Dell XPS 10 Motherboard Replacement: 步骤 2 中的图像 1,3 Dell XPS 10 Motherboard Replacement: 步骤 2 中的图像 2,3 Dell XPS 10 Motherboard Replacement: 步骤 2 中的图像 3,3
      • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
      • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
      • Unplug the connector the connects the battery to the mother board.
      • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
      询问修复机器人
      添加评论
    1. Dell XPS 10 Motherboard Replacement, Front and Rear Camera: 步骤 3 中的图像 1,3 Dell XPS 10 Motherboard Replacement, Front and Rear Camera: 步骤 3 中的图像 2,3 Dell XPS 10 Motherboard Replacement, Front and Rear Camera: 步骤 3 中的图像 3,3
      • Unscrew the two screws shown circled in red in the picture.
      • Use a #0 Phillips screwdriver to remove the two 4 mm screws
      • Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
      询问修复机器人
      添加评论
    2. Dell XPS 10 Motherboard Replacement: 步骤 4 中的图像 1,2 Dell XPS 10 Motherboard Replacement: 步骤 4 中的图像 2,2
      • After the rear facing camera is removed, you may now remove the front facing camera.
      • Use the nylon spudger to disconnect the cable on the motherboard.
      • Make sure you use the black plastic spudger to pry up the aluminum tape holding the front facing camera. Be careful as the tape is fragile.
      询问修复机器人
      添加评论
    1. Dell XPS 10 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Dell XPS 10 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Dell XPS 10 Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
      • Use the black spudger to remove all of the ribbon cables except for the wide orange cable.
      • Use a plastic opening tool to remove the orange cable.
      • Use a #0 Phillips screwdriver to remove the two 3 mm screws.
      询问修复机器人
      添加评论
    2. Dell XPS 10 Motherboard Replacement: 步骤 6 中的图像 1,3 Dell XPS 10 Motherboard Replacement: 步骤 6 中的图像 2,3 Dell XPS 10 Motherboard Replacement: 步骤 6 中的图像 3,3
      • Continue to disconnect all of the ribbon cables from the motherboard.
      • Using the black spudger, remove the aluminum tape from the wide black cable. Be careful not to tear the tape as it is fragile.
      • Use a #0 Phillips screwdriver to remove the final two 3 mm screws.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
James
于10/04/16注册
401 声望
创作了3篇指南
团队
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016 的会员
USFT-NANCE-F16S2G1
3 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 27
过去 30 天: 47
总计 2,451
