跳转到主内容
加入维修社区 - 创建账户
Dell XPS 10 Front and Rear Camera Replacement
你所需要的
    1. Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 1,3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 2,3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 3,3
      • Unscrew the two screws shown circled in red in the picture.
      • Use a #0 Phillips screwdriver to remove the two 4 mm screws
      • Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
      询问修复机器人
      添加评论
    2. Dell XPS 10 Front and Rear Camera Replacement: 步骤 2 中的图像 1,2 Dell XPS 10 Front and Rear Camera Replacement: 步骤 2 中的图像 2,2
      • After the rear facing camera is removed, you may now remove the front facing camera.
      • Use the nylon spudger to disconnect the cable on the motherboard.
      • Make sure you use the black plastic spudger to pry up the aluminum tape holding the front facing camera. Be careful as the tape is fragile.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
James
于10/04/16注册
401 声望
创作了3篇指南
团队
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016 的会员
USFT-NANCE-F16S2G1
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 60
总计 693
