跳转到主内容
Dell XPS 10 Front and Rear Camera Replacement
你所需要的
  1. Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 1,3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 2,3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 3,3
    • Unscrew the two screws shown circled in red in the picture.
    • Use a #0 Phillips screwdriver to remove the two 4 mm screws
    • Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
  2. Dell XPS 10 Front and Rear Camera Replacement: 步骤 2 中的图像 1,2 Dell XPS 10 Front and Rear Camera Replacement: 步骤 2 中的图像 2,2
    • After the rear facing camera is removed, you may now remove the front facing camera.
    • Use the nylon spudger to disconnect the cable on the motherboard.
    • Make sure you use the black plastic spudger to pry up the aluminum tape holding the front facing camera. Be careful as the tape is fragile.
结论
James
于10/04/16注册
401 声望
创作了3篇指南
团队
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016 的会员
USFT-NANCE-F16S2G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 308
