跳转到主内容
加入维修社区 - 创建账户
Dell XPS 10 Battery Replacement
你所需要的
  1. Dell XPS 10 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell XPS 10 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell XPS 10 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Battery Replacement: 步骤 2 中的图像 1,3 Dell XPS 10 Battery Replacement: 步骤 2 中的图像 2,3 Dell XPS 10 Battery Replacement: 步骤 2 中的图像 3,3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
结论
2等其他人完成本指南。
saraspam
于09/28/16注册
244 声望
创作了2篇指南
团队
USF Tampa, Team 2-1, Nance Fall 2016 USF Tampa, Team 2-1, Nance Fall 2016 的会员
USFT-NANCE-F16S2G1
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 21
总计 3,441
