跳转到主内容
Dell Wyse Xn0m Mouse Sensor Board Replacement
你所需要的
  1. Dell Wyse Xn0m Mouse Sensor Board Replacement, Mouse Sensor Board: 步骤 1 中的图像 1,1
    • Flip the device over. Unscrew nine marked 7mm Phillips #1 screws.
  2. Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 2 中的图像 1,2 Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 2 中的图像 2,2
    • Remove the keyboard by pushing back the tabs at the marked locations with a spudger or plastic opening tool.
  3. Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 3 中的图像 1,2 Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 3 中的图像 2,2
    • Turn the device around so the screen is closest to you. Lift the keyboard and detach the ribbon cable with the spudger.
    • To disconnect the cable, disengage the locking tab of the ZIF connector with the spudger and pull the cable out gently.
  4. Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard and set it aside. Detach the other ribbon cables with the spudger.
    • Remove five 8mm Phillips #1 screws.
  5. Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 5 中的图像 1,1
    • Pry open the laptop with the plastic opening tool.
  6. Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 6 中的图像 1,2 Dell Wyse Xn0m Mouse Sensor Board Replacement: 步骤 6 中的图像 2,2
    • Under the trackpad, detach the ribbon cables with the spudger.
    • Unscrew two 3mm Phillips #1 screws and lift the board from the pegs.
    • Remove the board from the laptop.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 656
